Sad day for me.......I just put in new 65# Motrons, and an Eric Mashsall chip. I started to tune it on the highway. I got about 3.5 degrees of knock retard at 23 lbs........and got out of it right away. I drove another 60 miles at normal speed (no boost) and noticed my coolant temp was starting to rise slowly. At 225 degrees I pulled over and noticed loud knocking coming from my engine......very loud like someone was smashing it with a sledge hammer. The last time I heard that I had spun a rod....:frown:
Anyway, I'd like some re-build advice. I don't have much cash,(wife says NO MORE!!!) but I do have a lot of engine re-building experience, and I have built one Turbo Buick engine before. I have a complete N/A 109 short-block from a 20,000 mile 87 Regal.....it's mint, so I'd like to use it as my staring point. Can I just clean and transfer components from the turbo bock over to the N/A block??? I'd like to use the turbo pistons and rods(re-sized), the N/A crank, I'd like to get new rings and lightly hone the bores, new gasket set and new oil punp and clean the snot out of the rad and turbo....or should I just spent the money on a TRW forged re-build kit from Summit Racing??? Will the standard sized (3.800) forged TRW pistons just drop right into the N/A standard bore without honing??? Any ideas appriciated........Cheers!!!
