I just installed an 85 GN setup in my Cutlass. I got the harness
second hand and two wires are cut. I'm trying to identify the
wires, my diagrams are no help.
1- On the back of the motor, by the knock sensor, I have a real fat
solid black wire probably 14 guage.
2- On the front of the motor, where the harness goes under the
ignition module, a small dark brown wire, 18 guage wire is cut. I
think it may hook to the alternator to feed the dash's idiot light.
By the way, I have two harnesses and neither have the standard GM two wire alternator plug. Puzzling?
Also, where do the two small water lines lead to on the front of the motor, just under the turbo. Do they go to bottom of the throttle body? If so, why?
Thanks, Brew
Thanks, Brew
