DougsfastZ
4.1
- Jan 30, 2004
Just installed alky in the car and trying to max out the stock turbo (23ish psi). I can't seem to get the boost stabilized. Right now it runs 18-19psi in 1st and 2nd then 22 in third. I've ported the wastegate hole to 15/16", running the RJC boost controller, bypassing the stock solenoid and adjusted the rod a few turns tighter. I even stretched the RJC controller spring a bit and can't get the boost stable. Should I go with a HD wastegate since I want to run 23 psi on the street? Would a carburator return spring help on the stock wastegate?
Thanks,
Doug D
Thanks,
Doug D
