Turbo Link Log 23 PSI test run...+10% fuel- zero Knock alky set at 6.5
BOP4ever
Temp was about 80-85 degrees and humid today. Car ran smooth I tried 2 more rounds on the waste gate, but I guess 23 PSI is all its going to give me. I had to abort the run early due to traffic so it was not a full 1/4 mile pull. guess 1/8 -1000 foot range...
IAC CTS VSS LV8 RPM TPS INT O2
135 194. 0 133 2000 1.51 128 640.63
135 194.72 0 154 2225 1.55 128 785.16
135 194.72 0 177 2400 3.49 128 812.5
113 194.72 20 255 4775 4.35 128 796.88
111 194.72 53 255 4700 4.35 128 781.25
111 194.72 50 255 4825 4.35 128 777.34
111 195.8 64 255 4475 4.35 128 773.44
111 195.8 74 255 4650 4.35 128 773.44
111 197.24 84 255 4800 4.35 128 761.72
117 197.24 90 73 3850 0.43 124 683.59
50 197.24 85 58 3550 0.43 112 671.88
44 will make more than 23 psi start turning that rod:)add a little more fuel at wot if you track the car as the street doesn't load the car like the dragstrip.
I hope it would my stock unit made 25 psi but has a different actuator.
This one is nearly bottomed out at 23. I thought the RJC valve would give me full control of boost but it seems to do nothing other than eliminating boost spikes which I had on the stock system of about 1 psi
I must have standard actuator on my 44 and a heavy duty on the stock unit.
Too bad they don't interchange.
