Steve87GN
Oh come on...its just a 6
- Dec 3, 2005
Well, after a couple years in retirement, I brought the mean "little" one back to the streets :biggrin:. Before the month is out, I need to get a smog check. She's never failed a check before, but I'm wondering what things I can do to make sure she passes with flying colors this time. Here's what I've done so far...
New vacuum block and gasket (old one actually broke on removal, go figure; part needed for vacuum brake conversion)
New K&N stock air filter
New Bosch platinum spark plugs (O.E. heat range, etc.)
...,still need to do...
Oil change (going to Royal Purple w/ K&N oil filter)
Fuel filter (picked up a Fram unit at Kragen, should be good, right?)
New wastegate solenoid filter
...and am wondering about...
New oxygen sensor - how long would it take the ECM to recal. to the new sensor, since it would more-than-likely be more responsive than the current one I would imagine?
Convert to heated oxygen sensor - would this cause me to fail the visual on a CA smog check?
Anything else I'm missing or could do?
Thanks as always :smile:
