Need help on balancing stage 2 motor all machine work in done except for balancing the rotating mass like crank,rods pistons,pins,flywheel and balancer.The machine shop had trouble balancing the crankshaft because there was alot of material meaning metal removed that i had to weld back on the bob weights.The crank i have is LA billet 3.590 billet crank,carrillo 6.5 on center rods wide journal 741 grams,CP pistons with pins,total seal rings,JW wheel and BMS steel balancer with sensor rings.The problem was that the crank had about six 1 inch dia. by 3/4 deep holes drilled with one mallory slug and the machine shop said it was almost impossible to balance the crank without filling back the drilled holes.Has anyone had this problem before and how many slugs of mallory will it take to balance my crank with the parts i have thanks.
