Removed EGR, keep solenoid connected?
V6UnderPressure
The Artist FKA Scott4DMny
I just installed a champion intake that has the egr milled down. I would like to keep the wire connected to make it look cleaner instead of taping it up. I was going to install it onto the firewall, plug in the connector and just put caps over all the vacuum connections. Should I run into any problems? I am running a classis FAST sequential by the way.
Just pull it back and tuck it in the wire loom, no need for it to be plugged in. Don't make come down there;)
tom , you know you arent allowed to route vacuum lines by yourself!
the egr is not functional with the fast. toss the box and hide the wire inside the loom or under the coilpack
