I read somewhere to check if an injector is leaking is to monitor the fuel pressure gauge after the car has been turned off. I noticed before my fpr gauge was reading 40 at idle (vacuum on), after the car was turned off I monitored the gauge 10 minutes later and the reading was around 26. It usually stops around 20.
Is one of my injectors leaking? Should it always hold the pressure without any movement?
These are stock injectors, is it time for new ones? If so, I've heard alot of good things about the blue tops. However, these cannot be purchased new anymore. Would it make sense to go with used blue tops or get other ones? I will eventually go with a bigger turbo (TA-49).
I don't know for sure how fast I want to run the car. Was thinking around low 12's possible high 11's. The car may become my daily driver for a while.
Thanks in advance!
Dannyo
Thanks in advance!
Dannyo
