TheGovernment
- May 2, 2010
I just swapped my old IC for a new PTE stretch one. After getting everything installed I went for a drive, everything worked great no problems. The next day I noticed a odd noise when hitting about 10 lbs or so of boost. The turbo sounds like it's sputtering or breaking up, like what you would hear if you stuck a card in a fan (there is nothing in there, just trying to explain the sound). There doesn't seem to be a loss in power and it runs great but it's driving me nuts! I've checked all my hoses and vac lines and they seem to be fine. My scanmaster numbers are fine also, nothing has really changed other than the IC. I never had this problem before with the stock IC. It almost sounds like a leak but when I took everything off (cold air, ic hoses etc) they are tight and don't appear to be leaking as I sprayed them with some soap to see if I could see a leak.
any ideas? It just seems like it has to be a hose or something, snice nothing else was taken off but who knows, maybe I have some other problem? my mods are in my sig.
