I've got a problem for all the transmission guys.
I had my 200-4r rebuilt after suddenly loosing all gears . After installing with new converter I went for a test drive and all seemed well until I down shifted to D at about 15 MPH and the car slowed down . I give it more throttle and the car still slows down. After getting back home I lift the rear tires off the ground and put the car in OD the tires start spinning. As soon I down shift into any gear the tires come to a sudden stop. Reverse works fine and it works as normal in OD.
It is under warranty but I would have to pull it back out and take it 3 hours away. So I'm hoping it may be something I could easily fix if you guys have any ideas.
