Im sure this has be asked a bunch of times but having trouble searching for the exact problem. I bout a set of 1157 LED bulbs. They say it also replaces 2057. Also got some 194 LEDs. Replaced all the 194s and they look good. Could only find one box of 2 bulbs for the 1157. Figured I would try them out. Wanted to try it out many years ago but the only LED bulbs were to large to fit in the tail light hole. I saw them on the shelf and figured what the hell. I popped in 2 of the 1157 on the passenger side and the brakes and turn signal worked fine. I ordered the second set for the driver side. When I installed them. Everything lights up when I turn the key on and switch but the turn signals and brake lights dont work.....even the high mounted brake light that is still a standard bulb. I am aware of the fast blinking problem but know that our cars dont have that problem. The package said "will not throw an error code". Figured this would have solved the problem. Guess not.
