Well...we're going to attempt to install the following on a friend's T-Type:
102046 VSS CONVERTER MODULE
102007 VDO SIGNAL CONVERTER MODULE
102049 Vehicle Speed Sensor (VSS) – Feed-Thru
The original dash has been removed.
It now has a GNX style dash with Phantom Autometer gauges.
The speedometer is working but it's bouncing around a bit.
The Scanmaster is NOT reading MPH.
It has a code 24 (obviously).
Questions for the instructions for the 102046:
1. Brown to Pin A10 of the ECM: Do I tap into it or do I cut the brown wire and wire it directly into the VSS Converter Module?
2. The Black -12 VDC and Red +12 VDC says to connect to a Switched 12 VDC. Do I tap those into the OEM VSS module?
Questions for the instructions for the 102049:
1. Where and how on the transmission?
Questions for the instructions for the 102007:
1. The yellow wire goes to the "cruise control module input". Where is that? Is that pin D of the OEM VSS module "cruise signal"?
I'm sure as the day goes by we'll have more...right now we're going to tear apart the dash and see what's back there.
First hiccup:
There are no terminals on the back of the speedometer. There is the speedometer cable and two wires going to the bulb.
First hiccup:
