I have read other posts on this subject and am still in a quandry about my situation.
The code 42 appears after highway running. Usually after I come off the exit to a stop, It usually codes as I am sitting waiting for the light to change. It will also come on after running hard, high acceleration mode and usually does not appear during normal 'around town' driving.
Does this error say my ignition module is going bad? Could this be dirty connections or a bad wire, as per the other post It seems to be getting more frequent. Another thing, the service engine light used to go off after a few seconds but is starting to stay on longer, until restart.
I can't see any other strange readings on my direct scan. Even when it codes there are really no others indicators. I do get a 0 o2 reading after revving the engine for a seconds as it drops to idle but it picks right back up.
Have the Casper heated o2, cold air intake, 009s, and using direct scan. Other than that basically stock under the hood.
Any ideas?
Any ideas?
