Hi All
I need help... I failed emissions test on high NOX using a TurboTweak 36lb emissions chip!!! FP was set to 38psi off according to Eric's instruction.
driiving 2525 test
HC (llimit - 90) - 81
CO (llimit - 0.50) - 0.03
NOX (llimit - 979) - 1878 <-- failed
curb test
HC (llimit - 300) - 70
CO (llimit - 1.50) - 0.01
I just checked the EGR and the motor stumbles when I press the EGR. The 3" cat does is not plugged... and it is the same cat that passed the test 2 years ago when the 150k motor was still stock.
I'm going to put in another EGR and a friend's cat just in case.
What else can I check for!!!!! The new motor (2000+ miles) is slightly modded with ported upper & lower intake, power plate, 62mm TB and some headwork.
I checked the website & most response to high NOX is the EGR system. Beside the EGR valve... what else can I check for, how this the EGR system work!!
thanks in advance.... dave
driiving 2525 test
curb test
