Electrical.
Donald Smith
I am having a problem with no power to my seat. Before I check into the wiring leading under the dash I'm hoping someone can give me a pointer or two on what to look for. I Checked the fuses and all are ok.....But,,I didnot find an actual fuse for the power seat. I am thinking that maybe its one of the relays located above the computor behind the glove box. I 'm also having a problem with the factory stereo. The L.E.D. does not light up at all. When i push the power switch the antena raises and i get static in the speakers but no L.E.D or tuning of stations. Thanks for any ideas?
30 ampere power accessory circuit breaker runs the seats.
Also runs the power door locks so try them for a good test of the power circuitry.
If the door locks work it's in the +12 feed to the seat switches.
Clock power is from the cig/clk fuse to the radio on the orange wire. Might be a factor or else internal to the radio most likely. :(
