ok guys i figured out all my knock probs so i put on my new pte-44, turbo mike elbow, and hooked up the hoses tuner style to get rock steady boost and i would just adjust it with teh rod. well with the rod all the way in i hooked it back on took it for a ride and got 17psi of rock steady boost. so i took the actuator off and took a little bit off so i can turn the end in more to shorten up the rod. well with the rod shortened, when i pull on it to put it on the pucks arm it cant get it to stretch out that far. so now what do i do?? does anyone make one that i can make short and be ale to stretch it out to get it on the arm?? i want to run about 20psi since im runing xylene with 17 psi and no knock so far but i cnat turn it up!! let me know my options here, thanks
