lyonsd
- May 24, 2001
This is what happened when I replaced the stock injectors with MSD 50s.
Before I did the injector swap, I put in the TurboLink boost sensinr harness and 3 bar MAP sensor. Car ran fine with that and stock injectors and JC chip.
Then I put in the MSD 50s and JC variable timing chip for 50lb injectors.
Started it up and it sounds like it's missing - idles like this: rump rump rump rump... Give it some gas and black smoke pours out the tailpipes.
Could I have gotten the plug wires crossed somewhere? Where is there a diagram that shows which plug goes with which terminal on the coil pack? I'll check that first.
What else could be wrong?
