Anyone running flex fuel sensor on xfi 2.05?
2GNS4ME
Just curious if anyone is running xfi 2.05 with flex sensor? If so how is it working out for you? Is it pulling timing correctly depending on octane content?
Debating if I should keep my thumbwheel or go with the sensor since it pulls timing now.
I've been running one for years and have flex sensors on both my cars. Works great since I like to use a mix of e85 and e98 or bump up low e numbers to get it above e85.
No issues works with pump and e98 ans adjusts as nessary.
Thanks for the quick response. Are you manually adjusting the boost according to octane content or does it tie in to the xfi system?
My boost is pretty much set. If I run anything less then e85 I keep my foot out of it. I do run a boost controller but my boost settings are limited by me not the octane
