J jerrad Member Joined Aug 21, 2004 Jan 9, 2005 #1 im running high 12's and im wondering if i need airbags in the rear even though im launching straight. will it help me out on times?
T turbo2nr loading... Joined Aug 28, 2004 Jan 10, 2005 #2 Maybe, are you experiencing wheel spin? Using T-brake? Raising the front left wheel?
J jerrad Member Joined Aug 21, 2004 Jan 10, 2005 #3 no wheel spin, and no im not lifting the wheel. im using my foot brake and when i get to 7 pounds the back right tire starts to break loose
T turbo2nr loading... Joined Aug 28, 2004 Jan 11, 2005 #4 Put your batt. in the trunk. Air bags are cheap, try one in the Rt. side
J jerrad Member Joined Aug 21, 2004 Jan 11, 2005 #5 ok. how many pounds do i need to start out at and then work my way up? thanks
T turbo2nr loading... Joined Aug 28, 2004 Jan 11, 2005 #6 12lbs. An ATR rear sway bar does wonders also. Try a better pinion snubber. All those thing are cheap, and add up to measurable differences.
