boostjunkie
NEED MORE BOOST
- May 27, 2001
1986 WH1 i was selling this car as a roller this summer but now have the car up and running this is the link for the car with some info http://www.turbobuick.com/forums/cars-sale/245677-1986-wh1-roller-project-car.html since i have replaced all the bumper fillers installed a good running stock motor with STD/STD Turbo Crank and BRF trans .
Just installed
Terry Houston down pipe with cut out
Reds Double Pumper fuel pumps
QA1 12 way adj FT shocks 90/10 Rear Shocks
Drive Shaft loop
Aluminum Drive shaft
Chrome molly Tube Lower Rear Controll Arms w/ Brace Kit From Upper to lowers
Adjustable Upper Rear A Arms
Full Rebuild 8.5 rear w/ Moser 28 spline axles C Clip Elms Full Spool GM 323 Gears all new bearings seals sandblasted and painted housing with GM Perf Aluminum Rear Cover all new brake parts
18 Row Stock location Intercooler
Alky Controll Twin Nozzle
2800 stall Lock Up Conv
55lb injectors with TT chip
3 Core HD Rad
Trans Cooler
GNX GTA Wheels with ET Streets
Nice Chrome bumpers with Aluminum supports and light weight Bumper Shocks
99% Rust Free car with rust in RT door bottom only rest of car is clean as a pin with never any rust or repairs (have clean RT door with new black paint to go with the car ) I am Building a New Car over the winter and this car needs to go to help fund the new project . Also have a STD bore 109 short Block with 2 center main caps Studs ported polished and pined heads ported stock headers to go with the car
$7500 OBO Shawn
Just installed
Drive Shaft loop
3 Core HD Rad
Trans Cooler
$7500 OBO Shawn
