10/10 turbo crank must check it/may need a polish/came from running project....125
fresh 109 short block
10/10 turbo crank/resized rods/arp bolts/arp main studs
std trw forged pistons/rings
stock flexplate/balancer/rotating assembly balanced/neo rear seal
100 mile 204/214 ede cam i took out of my roller motor that is in my car now/with lifters
cloyes timing chain/tensioner
good used gm cover/new stock pump/earl brown mods/clearenced/new filter adapter
stock oil pan included
8445 heads were done about 20k ago/there fine just need to clean for reassembly to short block/also have the new springs from the ede cam and they will come with/arp head bolts
stock lower intake/doghouse/i also have hardware to assemble most of this engine/what you see in the pics will be included if i missed something here.
Short block was built by williams engine service in freeport long island 516 868 3745 dave/im sure if you have a question about this build he will gladly answer it. I prefer a local deal for now i am located in brooklyn ny 11228/vinny 718-216-4410/ the one thing i will do is to the local trans builders i will be willing to work a deal for a built trans/convertor.
Price is 4k for everything/////////////must sell/////////project is not going to happen and i need the funds for a trans build..............thnx vinny
