My setup is currently done, but am going through and changing a few things. Stage II on center with stage II heads and roller cam bearings. I am downgrading from the dutweiller pump and high volume cover which uses high volume big block gears to a more sane standard cover with dutweiller pump using standard V-6 high volume gears. My motor was originally setup for hydraulic roller and Champions, but is now solid roller with the stage II heads. What do I need to look at as far as restricting oil to the top end or the lifters? Fairly healthy 9.0 @ 150 motor that is street driven. I was thinking of adding drainback holes in the valley to aid drainback and to get a little splash oiling on the cam at lower rpms since nothing is coming out the cam bearings. I also wanted to step down the oil pump since I should not need that volume of oil with roller cam bearings and the solid lifters. All valvetrain oiling is through the pushrods.
Greg Kring
9.0 @ 150
Arlington, Texas
Greg Kring
9.0 @ 150
Arlington, Texas
