F
FastGSXauto
Guest
From reading your threads, you guys seem to run primarily alcohol, with some water to keep it less flammable. I don't understand this. The objective of my water/acohol injection is to get cyclinder air temperatures lower to prevent detonation.
True, water does not provide any fuel, which is a necessary part of the combustion equation. However once we are over the stoich ratio of air to fuel, no more fuel is needed for the combustion. And we are well over stoich already with out fuel systems. In fact additional fuel ( or water ) makes less power because it displaces the air. But this allows us to run higher boost, which outweighs any losses.
So we are injecting water/fuel purely as an anti detonant, not as a provider of combustion fuel. With this established, the properties of water are superior to the properties of methanol, ethanol, isopropyl or any other alcohol. Specifically, the latent heat of fusion is 3 times as high in water as in the others. This property is the amount of heat absorbed when the liquid changes to a gas, which is where the majority of the air cooling takes place. In addition, water has infinite octane. It will not flash ignite. So my question, why are you guys using alcohol instead of water? I really want to know if I am missing something.
