you will need to switch to the car intake, or a single plane with elbow. Also the truck accesories will fit under the hood, but you might as well change them since the power steering doesnt fit by the steering box.
Also if your not very good with tuning, i would highly suggest getting HPTuners Pro. HPT has a much more useable and user freindly scanner, and with the pro you can input a wideband source. Just set the AFRs where you want them and it gives you a % error, copy and paste into the VE a couple times and the fueling is done.
+1 on the ARP rod bolts, but the main and head bolts are far more than adequate so dont waste your $ on them until you rebuild. Also when the time comes a set of COMP 918 springs or Patriot dual springs will be nice with a small cam.
One other thing, my friend still has a nice small comp cam and an f-body oil pan he may be willing to sell. Hell he even has a edelbrock single plane with elbow and set of 65# injectors with rails he will sell if your interested. This was all on a 4.8 and was making 425hp or so. Buy that stuff and HP Tuners and youll can have the complete 2-bar SD tune that we already have done.
