my current combo is a TE45, 72 lb injector, Trans + with Extreme chip (love it!!) and an older easern front mount. 3.5 MAF, GN1 heads, 206 billet roller, TH dp, XP dbl pumper
at above 10 psi at part throttle, turbo surges pretty bad shifting into 3rd. car studders and then picks back up. doesn't seem to do this at WOT, but with as much power as this combo makes, I can't hook up very well with street tires at WOT so I end up with the car surging quite a bit. it's especially noticeable going into 4th gear (boost gauge flutters down and picks back up).
I need to get some direct scan readings, and talk to the mad scientist (bob) more but is there anything I could do to keep the car from surging???
changing the intercooler or plumbing??? or is this just kinda a side effect of the front mounts and the larger turbos.
would a blow off valve help this condition???
I posted this a while back but didn't really get any ideas on what to do to fix this.
thanks!!
thanks!!
