Jason Littleton
- Mar 20, 2013
its just there is so much static as is i don't know if its the deck wiring speakers or all of the above hence why i just wanna do all new and basically i wanted diagram to be able to comprehend
if the dash speakers are tied into door speakers or if they need there own channel
lets put it this way at wot stereo pretty cranked all i can here is spool and drone (dam 3 inch muffler tech exhaust )
as far as the door speakers being tied into the dash speakers you would probably need a crossover. At least I would do a crossover so you can filter the dash speakers with not as much low (kind of like tweeters) and put a little more low freq. on the dash.
It has been a long time since I have done audio though. P.S I would also amp all the speakers if your running new wire. That's what I'm doing.
Ok so to edit again. (sorry very tired) I should also mention running new wire is extremely easy. especially using a crossover and amp. It is almost self explanatory if you read all the instructions/manuals. If your new to audio buy the crossover from crutchfield and you get install info and free tech support.
