Julian came down for a visit today. The weather and roads where crappy so he left me the car. I swapped tires from the car in my avatar as well as the driveshaft. Ran the car on the rack and watched the driveshaft, the compared to my T on the other rack...his shaft appears bent in the middle. So I put mine in and still does it. Checked runout on the axles and they where about .010 and visually had the same wobble as my T. The trans tailshaft bushing is a bit loose and I hate to tear a tranny apart just to change that bushing and have it not fix it. I then opened the rear end and took it apart. I found the bolt that holds the pin in broke and had to drill it out. I also found one of the carrier gearings just starting to pit. So nothing concrete yet. I had bad carriers bearings in my GN this summer and no vibrations at all.
One thought is this car just does not like poly bushings. Although I did a frame off last winter on a local GN and it has no vibrations like this and I used poly everywhere minus the from control arms....trans crossmember, body bushings, rear control arms are all poly. I also have a mix of poly and OE on my GN and no vibrations either..lol. these damn cars sometimes they just kick your but. I and going to take some driveshaft runout reading when I get the rear together. maybe the yoke is of center .
