Yepper. Someone added the extra height of the square tube (probably in the early 90's). Stock, the flange was bolted directly to the frame.
It should not be on the snubber at ride height. I know where you are going with that questionIs it possible for these things to transfer vibration into the car?
Could be rear control arm bushings are worn. Under hard throttle it be causing excessive pinion angle. Just a thought.Before the new tires it was constant above 70mph. Now it can cruise 70+ but the vibrations start under heavy throttle.
