I'm not sure what the numbers designate but the CAS I've seen were good
CAS V-4 = SLIC and I believe the CAS V-2 = FMIC.
Could the 2.5" exhaust be holding you back any?
Isn't the Cas v4 and the Dequick one and the same?That would include the CAS V-4, correct?
yesIsn't the Cas v4 and the Dequick one and the same?
Also V-1 and V-3 were FM's..CAS V-4 = SLIC and I believe the CAS V-2 = FMIC.
Has the front end of your car been lowered much?
I originally wanted to use a larger SLIC, but was concerned about the lack of ground clearance.
I have a mark Jackson double core its the biggest slic ive seen the necks are pretty tight to the top of the core to raise it up a bit,but it still hangs real low you have to have tight front shocks or it will scrape . a core and a half are plenty enough for 10sMy Mease 15 row (1 1/2 stocker) SLIC sits approx. 1" higher than the bottom of the stock I/C scoop as I suspect other 1 1/2 stockers would as well.
I believe Mark Jackson and some others made 17 row I/C's that would be about the same hight as the bottom of the stock I/C scoop.
It seems that 19 thru 23 row I/C's vary in ground clearance because the different builders raise the cores up different amounts to provide more ground clearance,
Research the one you're thinking about to see if you can find ground clearance information.
CAS =Charged Air Systems by Toney DequickIsn't the Cas v4 and the Dequick one and the same?
The better of the stock location Intercoolers out there (precision, dequick, RA) all flow more than most of the commercially available front mounts .
Yep. V1 = big race FMIC, V2 regular FMIC, V4 = SLICCAS V-4 = SLIC and I believe the CAS V-2 = FMIC.
What about the old Bowling Green Customs Extended SLIC? Is it better or equivalent to an old school Kenne Bell Big Boy fmic?
Only thing i can add about the BGC one is that it weighs a ton.
