I have owned a GN for 10 years now, and this board and it's members have been very helpful throughout the years. I have read these posts for a long time and learned a lot, and of course read the posts detailing someone else's abject frustration with these cars, and threatening to sell the car off cheap or even destroy it. I never have posted one until now.
I regrettably have finally joined the ranks. I never before have carried on about hating this car on here in 10 years, but here I am. I am tired of fixing this car. It seems you get it right for a while, and there it is, something else is broken.
This latest episode started late last fall when the cam gear and cam sensor gear decided they no longer wanted to play nice, this being brought on by some unknowing prior owner buying nearly everything in the Kenne Bell catalog, including a high volume pump that is completely unnecessary. This additional load ate the gears.
After a cam and lifter change and basically a total top end rebuild, I get this car back together and it runs and drives great at less than 1/3 throttle. It idles smoothly (except for occasionally going up 500 rpm and back for no reason at a light) and drives great until you put your foot into it. Then it stumbles or even backfires.
Changed the MAF as the values for it seemed low and I last changed it in 2002, and wow the problem was fixed for about 3 miles. Then right back at it again. WTF?
It acts lean, but T link shows the o2 values at 746, 804, 796, and 792 when it hit 3rd. The last 3 numbers are closed loop on the T Tweak chip. The 1st frame # is from a 15 mph rolling blast. Tps was 4.75 the whole time, and LV8 and MAF were both 255, and no trouble codes showing. NO knock at all.
Boost was at 15 psi solid the whole time, hitting 15.5 right before 3rd gear, then dropping to 14.
Fuel psi is @ 44 line off, FP does rise with boost. Idle vac ~16 or so in gear, steady.
After using my scantool as well as a friend's professional engine analyzer everything seems fine, except it didn't like the secondary ignition values. I am going to put fresh wires on it and regap the plugs @ .035 tomorrow, but my gut tells me there's more to this than that.
Any help would be awesome, if someone can help me get this thing running right again, I might decide to keep it. But this BS is making a coat of paint on the GN and ebay this spring real tempting. The 2010 Dodge Challenger isn't helping, either. At least I wouldn't be constantly fixing it.
Thanks for letting me vent, and thanks in advance for any help.
