motor ?
JC3569
Ok i will be reduing my motor soon should i build the bottom end with different rods or should i stick with the stock ones and put arp bolts in them.
I am only looking to go low 11s.Just want to no what i should do with the bottom end this car will be going to the track about 3 times a year.mostly driven on the street.want the bottom end to hold up.
thanx joe
Stock crank and rods are fine. Just upgrade them to ARP bolts. The ideal bottom end would be RJC girdle or billet caps. Depends on your budget.:biggrin: A stock bottom end will go 11's tuned correctly.;)
Here are some of your options:
1. Stock Rebuild
Stock Crank, new main and rod bearings, stock bolts
Stock Pistons, new rings
Stock Rods and bolts
New gaskets, Arp Head bolts, or head studs
Stock Heads New valve springs, valve job, resurface heads.
Assembly price.
2. Stock Block bored .020 over with Girdle
Hydraulic Roller Cam kit, Short Duration 206/210 may be nice.;)
(ARP rod bolts if you want,but you can get Scat rods for a good price)
Forged pistons, carful here, compression ratio will be effected
Stock Heads Fully ported,stock valves, or larger valves,
Assembly price.
3. Stock Block bored .020 over with 2 or 3 steel main caps
Forged crank and stock rods
Assembly price.
4. Stock Block bored .020 or .030 over with Girdle
Steel stroker crank, rod, and piston.
Hydraulic Roller Cam kit, Mild duration 212/212 may be nice.;)
or Champion or TA Aluminum Heads, hope you get the ported ones,
no sense in having to take them off to get it done later.
Assembly price.
This is just a simple list of combos for you to see where you would like to be price wise. You still need other things to meet your goals and most importantly a good tune.:cool:
info
1. Stock Rebuild
Assembly price.
Assembly price.
Assembly price.
Assembly price.
thanx for the info :biggrin:
