knock retard vs knock counts.......what's the difference and is there such a thing?
i have a cheap scan tool (monitor 85) that says "knock retard" but I don't believe it. reason is...the car seems to run good but the scan tool will continually count upwards 1 2 3 4 5 6 7...........30......etc.... I should also note that it only counts upward when i'm acclerating pretty hard (around 10 lbs boost). If i just drive normally and keep my foot say 3/4 throttle or less, then the scan tool just stays at the same number it left off at. And if i get into it again the numbers continue to climb. The only time the number goes back to zero is when the ignition is shut off and then turned back on, as if its re-setting itself. The reason i don't believe this is knock retard is because 1) the car runs good, with no pinging and 2) i don't see how a car can run with the timing retarded that much (30...50...100...).
Is this something different then knock retard? Do any other scan tools do this? Sould I be concerned?
Any info on this would be appreciated. Oh yea, the car is mostly stock, rebuilt a few thousand miles ago, and i'm running 93 octane in it. And I just got a laptop so I do plan on getting turbolink hopefully soon.
Thanks,
Eric
Thanks,
Eric
