haven't been on in a few years. I was thinking if I don't talk about it, I will forget about it. Well, several weeks ago I got my 86 GN out.
With the breakdown of 4 cars in the last two weeks (talk about luck) I was forced to put my GN on the road for the first time in 5 years.
I just put a brand new set of BFG's on this morn and headed to work. I started driving it wednesday and it ran fine. 125 miles round trip. 20 miles/gallon.
This morning I get stuck in the intersection and I gun it to get out of the way. Probably made 5-6 lbs of boost. I get about 3-400 yards up the road and I hear a grinding sound. Similar to no oil reaching the turbo. I dial up oil pressure and have about 47 lbs. Dial up 02 volts and I see 2.4-3.1 on retard timing. I let the window down and can tell the sound is coming from the motor. I immediately pull over and the sound is def. coming from bottom end like I wiped a journal bearing or something.
No knocking at all. has clean oil and enough oil. Opened Oil filter and no metal shavings.
What am i looking at here?
BTW, my wife tried to buy me a car wednesday to keep me from getting this thing out and driving it.
Running 93 octane gas, 255lph Walboro, hot wire kit, big mouth intake, TH 4" DP, Cotton's single shot, JE pistons, power plate, 3" up pipe, stock IC, dual fans, stock wheels/tire size, Champion Heads (stage 1). Called KDK (assembled motor) and Kevin said it detonated but couldn't be sure cause there is no knocking???
Where do I go from here?
