Snake Killer
- Apr 20, 2005
Hope you have nothing to do, this might be a long read.
After buying the car, everything ran great, no smoke, nice idle, new chip, replaced tires and all wheel bearings, life was good... One day driving down the freeway car starts making a grinding noise, but shortly goes away.. A few hours later I'm driving to the gas station, noise comes back this time a little louder. I immideitly shut the car off and coast into the station, pop the hood and check **** out, oil all over some smoke from the block, but maily from the oil spilling out on to it, but i thought i maybe blew the head gasket, but the oil wasnt coming from the head, it was shooting out of the Dip Stick, which was slightly Askew.
Now that means there is compression going down into the oil pan correct? This means it can be a host of problems, but i'm thinking maybe the rings are bad, or some seal somewhere isnt holding up.. I'm not really an engine guy, so I'm not sure what else it could be.. Once i got the car into the shop, i figured out the grinding noise was coming from the acc belt, where a bearing was completely gone and the fan was grinding on a bracket, causing sparks that made me **** my pants, since the motor was covered in oil... I doubt that has anything to do with my oil problem, and i've replaced the bearing and the belt, now i'm left with the option of pulling the motor tommorow to investigate, or hopefully someone on this board know his tech and can pinpoint the problem with the crappy detials i've given.
any help will be freakin awesome
TIA
Will
TIA
Will
