I hope I got this right.
Here is the extnsions and swivel I needed to get to the Bolt holding the hold down.
I also removed the up pipe and inlet tubes. I also had to move this clamp around so that I could get the ratchet in there.
Here is where I hope I got it right.
Look close, you are looking down on the Dampner. The White mark more close to you is the mark 1.4-1.5 from the TDC mark (its located lower on the dampner)
With the upper white mark set at 0, I used my volt gauge to set the Cam Sensor.
I atached the red prong and grounded the black prong. The reading was 6. I then rotated it around till it went to 0. I double checked it a few times and as soon as it went form 6 to 0, I locked it down.
I reattached everything and double checked connections. I then removed the positive wire from the battery.
I inspected my new TurboTweak Chip and was ready to install!!
I re-read the directions and "grounded" myself numerous times.
Then I went ahead and installed the chip. IT FIT!! LOL!!
I hooked the battery back up, turned the key and the SES light came, and stayed on. WOHOO!! I didnt FUGG the prongs up!!
I decided to take a quick break, look everything over, again, and start the GN.
It cranked a few times(New mini Starter sounds cool) but didnt fire.
The Batery died.
SO its on the charger now, and Im just waiting. Hopefully I did the adjustment correct(if not hopefully someone sees this in the next few minutes and warns my dumb ass) and its off to try and start her once again.
With great expectations,
Craig
