The old chain may LOOK good, but I'll bet there's chain wear marks in that old cam gear.
Like it was said, don't go hog wild on the valve spring tensions for this. I doubt it'll be running at 8,000 rpm.
The oil pumps are easy to take apart. Remove the oil cooler adaptor, then the 6 bolts. Check all the pump clearances; Side, end play, etc. You could add one of those Kenne Bell spacer plate for a little more oil volume, or even one of those longer gear oil pumps offered by several places.
Yes, you probably got at least a good coat of varnish on the oil pick up. It's held on by only 2 screws, so you may want to loctite them in when done.
While you have the pan off, you may want to consider.. ...ah, better not say anything else right now.
Yes, can get more than you may want to do right now, especially when nothing went right lately...
Where are you located?
