Ormand said:
According to Firestone, there was nothing wrong with their tires- except that FORD wanted them run with too little air pressure. You weren't involved in that decision, were you?
How do you know?
Anyways, everyone was at fault, including some vehicle owners in my opinion. The average tires looses about 1psi per 10 degrees in tempature drop. So if the temp drops 20 degrees out side, you're going to loose 2psi of tire pressure etc. Like stated above, most people don't check their tire pressure at all! This leads to uneven ware on the tire and even more serious issues like loss of vehicle control. Now the crazy part, none of this explains any of the issues I saw with the Firestone Wilderness ATF tires. Everyone of them I saw a problem with, was BRAND new on SUV's with less than 10k on them during the summer. These tires sperated on people driving down the road. I saw one Expedition loose a tire just after leaving the parking lot doing 20 mph...brand new! Then Ford /Firestone issued a recall stating we check for certain Dot numbers. these number where believed to be the bad tires...this held out until the new approved Dot numbered tires started poping as well. I later heard that some pissed off plant worker was spiking the rubber mix...even heard how some bugs crawled into the rubber mix and messed it up. All this info above and below was told by first person and not some memo.
Anyhow, as far as Firestone is concerned, I live 150 miles from a Firtestone testing track. The only way to and from there track was basicaly from our Airport. They shipped the cars/tires by truck and everyone else flew. Since I do tons of traveling I always ended up chatting with some of them heading out to the track. They told me that Ford ordered the wrong type of tire made for the Explorer...keep in mind I saw 50/50 on tire seperation for the Firstones. Anyhow, why Firestone even made the tire that according to them wouldn't be safe is beyound me. They also told me about the tire pressure loosing psi during tempature loss, as well as all the failed tires was 10 years or older. They couldn't explain to me how I had brand new Firestone wilderness ATF's poping on me
The next year or so, Ford redid some suspenssion work on the new Explorers. I left shortly after this started and never looked into what was done to improve them. These tires was baned world wide before Ford/Firestone recalled the tires.
Now for a weird one, guess what tire GM installed on their SUV's in the following years
Ok, it wasn't the Firestone Wilderness AFT's, It was the Firestone Filderness LS or something like that. I always found that to be funnt for some odd reason.
Anyways, I can go forever on faulty parts from Ford but I really would like to see some thread/reports on Faulty 80' GN Ball joints or Springs! I know I can find pages on the PM's but can't seem to find anything about the other.
