Ok...car ran 11.9@114 in 2008, slowly since then its gotten slower and slower. Since then I've added Cpt62ball bearing turbo, fmic, 3.5" dp, 60lb injectors, trans with transbrake, alcohol injection. Car runs and drives great, under wot its smooth, no popping or issues. O2 volts in 3rd gear were 772, 0 degrees of knock and 20psi of boost...car ran 13.0@99!...where's the power?..I obviously hVe some major issue since my mph is basically slightly better than stock. Conpression test...1-125, 2-135, 3-130, 4-146, 5-135, 6-140...are these acceptable? ..car does have some lag, i installed t and a replacement headers this past winter, I even turned off alcohol and changed chips with race gas..no difference. Any help would be greatly appreciated
