Originally posted by rev. 3:11
Hey!
I recently did a search and found a post by "murphster", there are about a million ways to install but I did it like his;
Basically, you:
1.) Remove the 4 mounting tabs from the new fans, a hacksaw works great, I put it face down and used the edge of the shroud to guide the blade. The plastic is very easy to cut (takes less than 2 minutes total)
2.) Remove the bottom bracket from the original fan (you'll reuse it in a minute)
3.) Install new fans (they will probably fit right in between the tanks), plug in harness.
4.)Take the bottom bracket, flip it over, and mount it along w/ the a/c line brackets at the top of the radiator. The bracket will trap the top of the fans and snug 'em down holding everything in place.
The whole thing took me about 10 minutes total, probably less.
(I spent most of the time seating the fans in properly)
Double-check by turning on the A/C and the fans should kick-in.
My temps didn't get over 170* (w/ a 60* stat) and we have ridiculously high humidity and temps down here.
Hope that helps!
Darrell
