Okay well I thought it was my cam sensor being out of wacky and after messing around with trying to make sure it was set correctly I just bought the Caspers one...the problem is it will start but idle and run really rough like it has a big ass cam....I have been going through everything with the scanmaster and everything is within spec....the problem is my spark plugs keep getting soaked with gas but I held the spark plug to the valve cover and they are all firing correctly....I did notice when I turn the car off the fuel pressure drops from 42 to 30 but then rises back up again all within a few seconds of being shut off...so I'm planning on pulling the harness of each injector one at a time to see if it changes the idle like it should but other then that I'm not really sure if I'm going in the right direction any ideas here? I pulled the crank sensor already and made sure it was working correctly and spaced correctly also. Thanks in advance everyone
