Hello CK,
I PM'd you back in April about my trans pressure problem, the burnt band, and the gear noise in OD. Well, I've finally gotten back to work on this problem.
I replaced your white/pink pressure regulator spring with a blue/purple one and this definitly got the pressures up. I would like some feedback about these pressures. Your 1st thought was a possible leak in the signal pipe. The original pressures are pink the new pressures are blue
-----------MIN TV----------------MAX TV-------
PARK/NUET--75--130-------------230--270------
REVERSE----130--235------------285--270------
D4/D3-------75--130-------------235--270------
D2/D1------162--270-------------162--270------
