firebird672002
- Sep 29, 2008
I have decent pressures and pressure rise with throttle application when the trans is cold. After about 15 minutes of highway driving, the pressure starts to fluctuate and drop. Clutches start to slip with acceleration. For example, at part throttle cruise, I'm seeing 150psi cold. After warm up its maybe 100. At cold wide open throttle 4-3 downshift I see a fluctuating needle but 230-240 psi. After warm up i see WOT pressure rise barely from 100 to 130. So I drive home and take some hot pressure readings and here they are-
NO TV / FULL TV
P 100 100
R 60 60
N 95 95
OD 70 60
D 70 60
2 70 60
1 50 50
Also when pulling the TV cable out the pressure rises slightly then drops back down. As you can see full TV actually lower than no tv. I have removed valve body and checked TV valve and other valves for smooth operation. I have checked the TV boost valve and PR spring and TCC valve. The trans did overheat from the slipping and the band is cooked. It is going to be rebuilt I am just trying to determine a cause so I know what to look for. Its a Extreme Automatics Stage II with less than 10,000 street miles. Never raced. Any thoughts? Thanks for your time
NO TV / FULL TV
P 100 100
R 60 60
N 95 95
OD 70 60
D 70 60
2 70 60
1 50 50
