turbonut85
Rarely used member
- Apr 11, 2008
Post a pic of the directions.
I have an aftermarket adjustable one but since my car was running so rich I keep it near factory pressure. Stock injectors tooSet the translator to base settings, i bet you that is NOT the problem. Your fuel pressure is kind of low, but not abnormal with a stock regulator (its a stock one, right?)
I forgot if you have stock injectors or not. Do you? Or are they aftermarket?
It is either a fuel problem or an air problem. Check ALL of your vacuum lines man.
Time to back up a little. You need to list your entire setup. Then we can try to narrow down where the potential issues could be, and what has been changed/altered.
What do you have for:
Injectors
Chip/(specs)
ECM
MAF sensor
Fuel pump...how old? What brand?
Fuel pump....hot wired?
o2 sensor...how old? What brand?
Engine harness grounds (under the a/c compressor)...tight?
ALL scanmaster #'s?
Post answers to all the above, and then we'll start from there.
After some research I have an idea....I think the stock 84-85 chip you have is conflicting with the MAF signal.
Just for laughs....if you can, swap back to the stock 85-85 ECM, MAF, and chip....then see if you're still running rich....
According to bob bailey, the translator emulates the 86-87 MAF signal and needs a chip setup for the 86-87 MAF....which your stock chip is not setup for.....
I was told my 86/87 ECM had a chip for an 86/87 car. I actually went through my messages from when I bought the ECM... I guess the guy said it has a hypertech chip in it... So its not for a stock car.... But you'd think the INTs wouldn't just max out at idle, but maybe thats what it is. Tomorrow maybe ill swap the 85 ECM back in and see if it runs better.That's not my point....I think it has to do with the 86-87 ECM and how it is calibrated to read MAF signal. I think it's in the chip. Anytime people convert to the 86-87 ECM, they get a new chip burned. The chip is setup for the 84-85 MAF sensor calibration....and it's conflicting with the 86-87 ECM....that's why I said to swap back to the 84-85 ECM with that chip....and see how it runs....
This "stock chip" you are referring to....stock 86-87 or stock 84-85?? The ECM is the correct number for an 86-87 turbo car. The calpack is the small chip. What you have to understand, is the chip (big chip) HAS to match the injectors you are running....otherwise it will not run correctly....period. A stock 86-87 chip in a hot air will not run correctly....especially if you aren't running stock injectors. This is why I (we) keep telling you to get a TT chip burned for your setup.
Glad to hear its running better. Be careful beating in the car with that 86-87 chip in there as the fueling and timing may be a touch aggressive for your hot air setup....hot airs are alot more sensative than the IC cars.
