Replaced the orifice tube on the GN this morning because the a/c was not getting cold. Recovered the R12,blew the system out & did pull a vacuum on the system for about 35 mins. at 30" Hg. After the addition of the R12 back into the system, the pressures are as follows: 35 lo & 225 hi side. Then after around 5 mins. pressures were around 38 lo & 275 hi- holding. Seems that the line on the orifice side going to the inside of the car (evaporator) is very cold but out the evaporator into the accumulator it is only cool (not enough for condensation to build up). Question is -with the pressures at 38 lo & 275 hi- the car is shut off and the equalization of the pressures on the gauges happens within 5-10 seconds. Is this normal or is the A/C compressor going bad? Could the water valve be leaking by? Help. South Texas Heat!
