I working on an 87 GN and I'm looking for the little white plastic clip that attaches the threaded rod behind the glove box to the pivot arm which is controlled by the temp cable. The clip inserts into the pivot arm and then attaches to the rod that goes into the evap box and I believe moves a door to switch from heat to cold.
Thanks.
Thanks.
