Dusty Bradford
- May 24, 2001
15x11 with 6 3/8 backspacing. Frame notched and mini tubbed with 14" 130# Qa1 coil over springs in the stock location. Tire is the 295/65 M/T radial
Thanks for the pics Dusty. I see what you mean now in regards to the 295 on the 11" rim. Mine's gonna sit pretty low with the ladder bars & coil overs, so I think if I cut 1" each end of the housing the 12" wheels whould work with a 325. What's your thoughts on this? THX.
I see what you mean Dusty. I think using the taller 295 might help get the tire inside the wheelwell more as I can go up due to the mini-tubs, but going wider won't be easy since the stock framerail will be used. I want to use the new Billet Specialties Streetlite wheels, but they only offer a 10" or 12" rim. No beadlocks here as I won't be in your's & Shane's speedzone :biggrin: I hope to get the new MMA business & website up by Jan. 1; don't you want a "SUBBMIT" sticker on your backwindow I'll be sponsoring Sully's "V6BEAST", so let me know if I can help you with anything. Thanks again & I'm sure I'll be picking your brain when I start on the front suspension.
Hey Rick
