T63 and T63e, whats the difference?
Look at the times in sig. l put the 63E turbo on in 1998. Harry Hruska talked me into it. :biggrin: I love the 0 pump 5 disc vigilante and stock motor set up. Both of my cars run better than I ever expected. The GN went almost 126MPH on its best run into a 10 MPH headwind and 75 degrees out. So it may go 127-128 I think on a great day.
The TTA with the GT3255 has trapped at 121.The tune could be better too.
My GN has run faster then my buddy with a 6765DBB and the same 5 disc vigilante. The boost was about the same too. Both upper 20s. So I am not sure how much more power the 6765 makes than the old school 63. His best MPH was 122.8 and mine was 125.8. Both cars are set up the same. And we run on the same tracks.
Wow your car is really moving, is this still on pump fuel and alky? A friend of mine wants to sell me a t63 with a .82 garret exhaust housing and just wanted to know what is the difference between a t63 and a t63e? What exhaust housing are you using on your turbo, and is it a garret or precision?
Thanks,
Marco.
T-Top 86 Grand National 62000 km)
stock long block, stock suspension, 12 inch red stripe convertor (2800stall), te44, smc alk injection (95 % etanol), 25.5lbs boost,( boost spike 28 psi in 1st gear), 94 octane, hooker cat back with dyno max ultra flow muffers, 42 ½ lbs 009 injectors, turbotweak alky chip with 23/21 timing, thdp, mease 24 row IC, Ron Custom max boost brake module, MT drag radials (275/50/15) 3720lbs race weight with driver. (Torque convertor locked only after car shifted in third), rjc power plate, rjc boost controller, zeitronix wideband, HR motor mounts, comp cam 980 valve springs. Weld Drag Lites with skinnies up front, electric exhaust cut-out.
BEST E/T
60FT=1.53
1/8= 7.25
1/4= 11.48
MPH=120.82
BEST 60FT=1.52
I have a gen 2 with an extender chip and LS1 MAF, hr rear sway bar, no front sway bar, 90/10 lakewood in the front and 50/50 lakewood shocks in the rear with energy suspension poly bushings all over, boxed rear lower control arms. MT 275/60/15 drag radials. Big mouth cold air with an AFE air filter. I did't get a chance to try this set-up. Taking out the stock 109 block and replacing with a rebuilt 109 with 2 center billet main caps, and weisco forged pistons.
