Weird Knock numbers!!!!
clean86
took the car out last nignt for the first time with the scanmaster. I put in my street chip from Precision and turned the boost down a little. When leaving with 12 lbs on the street the car spins about 10ft then hooks hars but as soon as I lift off the brake I get 19 deg of knk. Thinking it was false I did it again as it shifted 2nd it dropped to 3 in third it went away . I was only running 14 lbs of boost with pump gas fuel pres was 60 at wot and o2's were 800 is this thing just scaring the hell out of me or do I have an issue? I am installing my EGT tomarrow and compairing to make sure.If EGT's are good and I am seeing knock I assume it is false. Am I thinking right . Thx Guy's for any info.
