Great, thanks!
...no problem
Now, if you don't mind, what is the temperature of the air coming out of the turbo at say, 15lbs boost?
... Probably the bigger the turbo, the less the temp will be. And as long as its compressing air within its range, shouldnt get too high. At 15 PSI boost, with a cool turbo, no more than 20 degree's. The temp really picks up as the boost picks up. At 25 PSI.. 140-160 even higher
What is the temperature of that air coming out of a stock intercooler on an 80 degree day, with no heat soak on the intercooler?
...With no heat soak, same as ambient. At low boost levels.
What is the flash point of 100% denatured alchy?
(I only run 100% alchy.)
...Good question.. Dont know. Who are you buying the denatured from? Lets contact the MFG for a data sheet.
BTW, I am not arguing for water spraying on an intercooler, I am just trying to understand this "flash point" theory.
I had thought about water injection a while ago, and I decided against it becuase I thought that the spray would harm the intercooler. Seems to me it would start to break down the elements over time. Hot cold, hot cold. Not to mention the overspray that might accumulate over the engine area. Seems like an invitation for rust.
...I dont think rust would be an issue, I mean you drive through rain and such and that doesnt hurt the parts. Internally or externally. The severe temp drop from a CO2 sprayer.. that may have some wings on it as far as heat cycling the core.
