lol... thanx.... i found my wiring schematics last weekend and took care of it but thanx for the post... i am sure somebody will find this thread in the future
It is most likely a +12 volt signal. I didn't check a '7148 ECM, however, other ECMs of this era use a 5.1K ohm resistor to +12 volts as a pull-up.
The buffer box doesn't really output a voltage, it only pulls the signal to ground. Which is why the ECM has the PU resistor. IIRC, there are two outputs on the buffer, the other being used for the cruise control module in some vehicles.
